hotsparks
Sep 16, 2012Explorer
Hey Kev, were all still reading your updates. :C
I was just wondering how the hinges were on your doors. Are they very worn out and loose or are they snug and tight? Don't try to fit the door gaps with loose hinges. With the doors open see if you can wiggle the doors up or down. If the hinges are loose you can take the pins out and maybe drill the holes bigger and make up some larger pins to fit the larger holes. Then you can get some grease in there and make them swing nice and smooth.
I was thinking about this as I was reading because it reminded me of the time I made that mistake. I rebuilt an old 1968 MGB-GT and never fixed the door hinges. After I had the car all painted nice the doors later started to rub on the paint. After I fixed the hinges the door gaps were all different and I sort of had to do my body work over and repaint around the doors. After all that the doors worked good but the paint was sort of messed up and never looked as good as it used to. This all falls into the part about "just fix it right the first time".
I'm just wondering how is the budget holding out for this project? Or are you even keeping track? Have you kept track of how many hours you have worked on it so far? I know it is a lot. Keep it going. If you don't finish it will be all wasted time but I know you will finish. I can tell you will.
Good luck on your wedding, I hope you get to be old, fat, and happy someday. OK 2 out of 3, you can skip the part about getting fat.
:B
:B
