Kevbarlas1
Nov 12, 2015Explorer
Thanks guys, i really like the comments made on this forum :) , means a lot to me.
November 2015
Its been roughly 3 months since my last update but I've been a very busy boy.
The last time I put an up date I had just started doing the harling on the walls so I'll carry on from there.
I carried on doing the harling a section at a time, just mixing enough myself by hand so as not to waste much. It was also at this point I had chosen my colours for the walls and bought a couple of tester pots.
All the harling finished on the front.
Then I moved onto the rear of the garage and that got the same treatment.
After all that I wanted to get on with painting the walls. As the garage is made from concrete sections I bought some proper gap sealant designed for these panels and ran it in between all the panels. I didn't bother filling the gap at the bottom between the blocks and walls as inevitably water will find a way in and that gap should let the water evaporate rather than containing it. I got home from work on an unusually warm day in Scotland and went into beast mode.
Once the front wall was painted I went and bought a nice dark green for the door. I repaired the hole I had cut in it from removing the middle hinge. I also got another colour for the block work at the bottom as a nice contrast. If you look closely to the roof flashing you will notice a few pairs of vice grips. I had noticed when it rained a lot of water would come running down the flashings and drip randomly on the ground. Not a big deal but it kind of annoyed me. To remedy this I wanted a small mini gutter. I thought of getting some thin sheet metal and folding a U in it but then I had a good idea to use plasterers beading. Its already in a U shape plus being galvanised it was also protected. So I used that and stuck it on with some generic builders adhesive in a tube. Works a treat, now the water collects and drains from the side.
I liked the colour I used for the block work so I also painted the flashings the same colour. I also managed to get around to painting the roof panels in a nice slate grey, made them look brand new.
Then I moved on to the rear and painted that too.
I haven't done the side walls yet. I don't have much room right now as that's where I've been dumping my excess stuff and its just aesthetics right now which can wait until next year once the weather gets better again. I was focusing more on making what I see from my house/back road nice.
Exterior done, now its the inside needing done. I knew that as I was going to be spending quite a bit of time in there that I would want it to be comfortable, dry, warm, basically a happy place to be. First thing I done was order some 3x2 to make the studding, 13 sheets of 9mm ply for the walls.I chose ply for strength compared to plaster board and its also a lot easier on the eye compared to OSB board. Then I took a long weekend off work and got started.
I was a bit unsure of how to attach the studding to the garage walls and then I came across these L brackets. There intended to be used to tie in blocks to a wooden frame when building. I found with a bit of cutting the longer end I could use them with some washers to keep the frame tied to the wall.
A bit like this. I know I could have made my own but these were like 32p each and I needed 94 of them so it was a no brainer.
A few things I had ordered hadn't arrived yet so I couldn't put the insulation in at this point. I didn't want to waste my time off so I got on with cutting all the ply for the walls.
Once I had the whole thing framed and ply cut, I then took all the ply back off again and started looking for insulation. My cavity space was around 100mm, not much but better than nothing. I had thought of using the rigid board stuff like I used for the roof but changed my mind , due to price and the fact that each cavity wasn't really a easy shape to cut and it would be left with a few empty spaces. I went to B&Q and they had an offer on for attic insulation, 5 rolls of 100mm for the price of 4. Worked out to about £35, deal done! .
The rolls they came in were already pre-cut to 400mm wide, which was close enough to my spacing , bonus. Once the insulation was cut and teased into place I then moved onto running my electric cables, I put 6 double sockets in on a ring circuit using 2.5mm cable on a 32amp breaker. I also added 4 more fluorescent tubes and wired them in using 1.5mm cable on a 6amp breaker. Lastly I used 6mm cable for the dedicated 16amp socket for my welder. All fed by a 10mm cable running on a 40amp breaker in the house to a consumer unit in the garage on a 63amp RCD main.
I thought that if I'm going to the effort of insulating it I will go the whole hog and buy proper vapour barrier ( this is what had not arrived dfor my holiday in time) and got that into place.
Next up I put all the ply back on the walls and moved onto insulating the doors. This is when I did use rigid insulation board. I had some 50mm left over from the roof and my brother gave me some 100mm stuff that I cut in half for the front door. I had also painted the floor by this point. Oh, also , if you look closely a the bottom of the doors you will see the rubber seal that was stuck to the ground to stop any rain, dust, leaves etc from being blown in.
Getting there, so close now!!. To neaten things up inside I filled the joints and gaps with a cheap wood filler, I also added some nice skirting boards which you cant see here yet. I bought a small 3Kw heater and I tell you what. The garage may not have tons of insulation but it holds the heat really well. If its around 11-13 degrees outside I can put the heater on for around 45mins and I'm toasty. Once I get it to a comfortable temperature I put if off and haven't found myself having to put it back on for another 2-3 hours.
Atlast, the garage was complete inside and out. Now I needed to move all my ****. I spent the next 3 weekends in a row borrowing my work van. I didn't want to bring useless stuff along so I made a few piles, scrap, recycle tip, garage etc.. And sorted it all out. I had bought 2 nice shelving units ages ago so I built them up. My boss was kind enough to let me have the work bench that I used in the old place.
Id go there on the Saturday, move the stuff I needed into the garage, Sunday was dumping **** day and then id spend time after work organising shelf's, roof space, hooks etc... Until all but one thing was left. The van!
I thought of borrowing my friends trailer and doing it myself but then I remembered that the guy I sold what was let of the Silver Lexus LS400 could maybe help me out. I managed to get a hold of him and organised him to collect it on his loader and drop it off. I also got my dad to come along and help too.
Cut to this Tuesday (10/11/2015) around 10am and I went to the garage to take this last photo of the van in the surrounding its been in for the past 5 years (has it really been this long already!).
We rolled the van out on a really heavy rainy day and got it loaded. Looks tiny compared to a modern Mercedes Sprinter van.
Then we got to my freshly built garage and got it in :) . The guy that dropped it off for me is a top bloke. Done it for a great price and wasn't shy to help unload it and get it in the garage, cheers James!
Oh, you can also see the metal shutter I made for the windows here. Stop people looking in and a bit of extra security.
Plenty of space between the trusses and roof of the van.
I cant say how happy I am for this right now. Its been literally around a year since I drew my first plans for the garage and now I'm here, atlast. My van is in the garage I designed, researched, bought, built, etc.. I feel really proud right about now. The day I brought it back I was actually just happy to sit in my garage and reflect on what I've achieved for a good hour or so. I have everything I need here, inside is nice to look at, I have electricity, Its warm, Its water tight, still plenty of space to work around , heck, it even has Wi-Fi.
So of course this is the point where I say I'm back to working on the van. Id love to say that but as its nearly xmas the wife wants some piece of the house to be re-decorated. I think she made her point when she started to half strip the hallway about a month ago then abandon it so I have to finish it off now, yippee..........
Never mind, 2 weeks holiday from work over Xmas and I'm getting myself stuck in the garage then!
Expect an update around then, so long......
November 2015
38,780 PostsLatest Activity: Aug 05, 2026
