carringb
Dec 09, 2019Explorer
Cougargm wrote:
I wondered about that, Carringb, but I filled the tank the end of Sept. and it was leaking in early November. And I lost a lot of gas; wouldn't that have only burned a gallon or two?
The evap purge cycle doesn't occur all the time. I'm not sure when it calls for it, but it's definitely periodic. But no, I would not expect it to result in a massive fuel loss. Keep in mind a very small amount of leaking can cause a big puddle.
The reason I gravitate towards this theory is the intermittent nature. The rest of the lines are all under high pressure, so a leak is VERY noticeable. The only other thing that crosses my mind is a cracked filler hose, over the tank. But that *should* leak near the tank, unless it dripped onto the frame rail, and migrated away on the frame.
