TropicalRV
Nov 12, 2015Explorer
Sure, you can gamble that you will get a better ride by running your tires at lower pressures based on the axle weight. Actually, your load rating will be closer to a lower rated maximum and the factor of safety will be less too. Will you get a better ride? I'll bet you couldn't tell the difference. It's all in the mind. It's better to inflate the tires closer to the maximum sidewall rating because you will have more safety factor and lower your chances of a blowout.
