slickest1
Nov 13, 2015Explorer
parkmanaa wrote:
The main objective of pressure for the load is to assure the belts, viewing shoulder to shoulder, are flat on the pavement. Too much pressure: center has more pressure, narrowing the footprint, poor braking ability, rough ride, forcing stress on edge of the tread belts.
Underinflation, more stress on edge of belts, more flexing in sidewalls producing excessive heat buildup.
Both over & under inflation have many more detriments I won't take time to list, but that is why manufacturers publish PSI/load charts.'\
To address other questions, there is an age-old battle between vehicle (car, truck, RV, you name it), manufacturers and tire manufacturers. Vehicle manufacturers will typically recommend lower PSI, because they want the best ride, but tire manufacturers recommend higher PSI because they want to assure the tires give best mileage.
Bottom line, you are wrong if you overinflate, or if you underinflate, for the load you are carrying..............period ! ! ! !
That may be true for tires of years gone by like the old bias ply.
The basic design of a radial tire is to have the tread patch flat on the road and the sidewall does the flexing. That is why you have the bulge in the sidewall. The less air the bigger the bulge and the softer it will ride.The less air you run the more heat they will build.There is a little leeway in the pressure stamped on the sidewall, but mine say 110 psi and I will not go below 100.
I have sat through endless test videos on how tires really work and spent several years in the Industry. I then moved into the trucking industry and have worn out a heck of a pile of tires.
