xctraveler
Nov 19, 2015Explorer
Sam Spade wrote:holstein13 wrote:
Therefore, the burden is on you to get your coach weighed and look up the manufacture's proscribed inflation pressures.
Conditions vary for sure but.............
IF you get the same size and load range tires with the same max. pressure rating, I don't see how the recommendation at less than max. load is going to be that much different, no matter what brand they are.
I use my RV more like a camper; it doesn't have much extra load.
Those who use one like a mobile house probably should pay closer attention.
Even use as a "camper", whatever that means, may include fresh water in the fw tank, propane in the propane tank, one or more people on board and food, not to mention a few sundries like dishes and cooking stuff and just a change of clothes or two. You might be surprised at how fast that can get over 1,000 lbs. Just for laughs a giggles, weigh it empty and then set up for a camping trip and weigh it again, with the people who travel with you on board. Michelin seems to think a couple of hundred pounds of load makes a difference, but what do they know? they just engineered and built the tires.
38,782 PostsLatest Activity: Sep 10, 2026
