427435 wrote:
rgatijnet1 wrote:
If the engine overheats in a little over a mile, that indicates that you are NOT getting water circulation. This eliminates the fan clutch, transmission, dragging brakes, etc.
I would look at things that will stop the water from circulating like a bad thermostat or an air pocket in the cooling system that will cause the water pump to stop pumping. Check the thermostat with a pan of hot water to make sure that it opens completely and that it is installed correctly, and not backwards. Fill the system with water and properly bleed it to make sure that all air is removed.
Good suggestions.
The bottom radiator hose could be collapsing or plugged.  Make sure that there are new hoses in that $5000 worth of parts.
Check the hoses- If a hose has a tight bend it could cause collapsing. I have one vehicle where a spring the diameter of hose ID is inserted to prevent collapsing.
