Busskipper's avatar
Busskipper
Thermo Cube Thermostatically Controlled Outlet
Anyone Use This Cold Weather Thermo Cube Thermostatically Controlled Outlet - On at 35-Degrees/Off at 45-Degrees.
I keep a couple of 150 watt Halogens in the Coach during the winter, use them to keep the temp around 40, and the only problem is they are always on, even when it's warm out - found these on Amazon - just checking to see if anyone has used them?
If you have do they work? Would be nice to turn off the electric on the warm days.
What do you think?
