splasharizona
May 26, 2016Explorer
Thermostat Question-1995 Southwind Storm
Thermostat question...Is it common practice for someone to put in only the upper half of a thermostat or would using only the upper half of a thermostat possibly be a roadside fix to an overheating problem?
I have a 1995 Southwind Storm, gas on a Chevy P30 with a 7.4l 454 engine. I live in the Phoenix, AZ area. When I bought the coach almost three years ago the antifreeze was new, so I had no need to do anything to the cooling system until now. I decided to flush the cooling system, change the upper and lower hoses and thermostat. When I began the initial drain I pulled the engine side of the upper radiator hose and then the thermostat housing. What I discovered was a half of a thermostat in the housing, the top half. The entire lower half was nowhere to be found.
