wvabeer wrote:
I have been wanting another motor home and thinking about the pusher style . I know very little about diesel engines let alone rear transaxles. I know plenty about gas and can do everything on them but back to the subject. Which pusher chassis are most trouble free? I'm thinking about a used high end unit. Any suggestions from those experienced in these would be greatly appreciated.
well your idea is correct.go used higher end units.lots out there
the ISL/ISX can go up to 20000 miles on engine oil(about 4 years for me)although I change every 3 years.lifetime coolant and 300000 or more on trans oil.much higher rate ratings than any gasser ever made
you can not compare any gasser to any mid to upper DP motor home
