Mr_Mark1
Jan 16, 2017Explorer
Mr. Tohare,
The Tecma toilet in our '08 Dynasty drove me nuts sometimes. Ours did just as you describe, the black tank would be empty and would show green then flip back and forth to red or sometimes stay on red. Of course when it's red, you have to hold the button to get a flush.
Our Tecma toilet was also a macerator toilet. What helped tremendously was to 'back-flush' the toilet. With you having two toilets, this may not work.
I would fill the black tank with the sani-con system until the water started to come up into the toilet. Then I would run outside and release the black valve to get a good flow of water gushing out into the sewer drain. This worked to clean out the macerator part (I think) and it would work fine for a while.
Safe travels,
MM.
Safe travels,
MM.
