YC_1
Jan 16, 2017Nomad
If it is possible to get to the area where the sensors are you may be able to add an in tank sprayer. Just put a quick disconnect on a short piece of hose so you can switch between tank cleaners.
For some reason they installed my sprayer in the opposite end which does fine for cleaning the bottom of the tank but the spray does not clean the sensor area.
Even with that ours can act up like yours so I actually installed a deck access plate and can use my pressure washer.
I also found that a cup of liquid Dawn left sitting in the tank as long as possible seems to keep it clean,
We are full time and do not use any chemicals. Just plenty of water.
