lakings10's avatar
lakings10
Thor Axis/Vegas owner's I have few questions.
I've read all the threads on the axis/vegas but still have a few questions. I might be buying tomorrow.
How do you dump the tanks? The dump valve is pointing upwards and it seems like it wouldn't empty all the way.
The living room tv doesn't swivel? How do you get to the back of it? I'm planning to put a dish on mine and need to run wires back there.
Same question regarding the outside tv.
Are there any outlets in the bedroom to charge cell phones?
Does the shower curtin do a decent job keeping water in the shower and not all over the floor?
Sorry for all the questions, but looking to buy a 2015 Axis tomorrow. Thx again.
  • Driver side up under the dash. Have fun getting to it . It is a small fuse panel.
    You have to get on the floor lay on your back and contort yourself to find it and replace the fuse. I changed the fuse to a 7 amp instead of the 5 amp
  • Where was the 5 amp fuse for the windshield wiper switch located? I am having the same issue with mine and the techs can't find it.
  • To up date I have since cut the hole in the sewer compartment and made the plastic base of the bottom of the compartment a square and turned the sewer connection down and left it that way. I added a 45 degree clear elbow to the drain as well. So much easier to hook up and dump. Once done dumping, take hose off and put the cap on, close compartment door.
    Thor designer had a nightmare on that design so I made it right!!
  • Thor would be smart if they developed a DVD on the very detailed use of the Vegas motor home. As most dealers have no clue when it comes to salesman doing a walk through. In the 2015 Vegas the galley TV is not a swing out but can be removed from the mount by pulling down on the webbing strap. Make sure there are four hands while doing so. Pull down on the strap and have another holding the TV. For the sewer hookup the outlet is turned down before connecting the hose. Once the dumping is over and you are ready to pack up and hit the road you should raise the outlet back up and install the threaded circle back in the hole. I have been on the phone with the Thor rep for a number of times with improvements that need to be addressed with the Vegas model motor home. There are too many issues with it. The lack of quality control is very much in question as I see it. Our 2015 was back to the dealer's service department for a month to get our problems taken care of. The list I have given the rep is as follows.
    Cab was lacking any real cool air A/C was lacking on keeping driver and passenger cool. That was fixed with a new part. I ended up installing a curtain to close up the cab and to keep cool while driving. The window wipers stopped working and found it to be a 5 amp switch fuse. Replaced and they worked again. But had no window washer. That was found to be a bad washer fluid pump. That was changed out to a new one. The rear TV/ DVD player needs changes made as to hook up. The cable connection is right in the way to insert a DVD. I ended up installing a male/female 90 degree connector to get the cable wire out of the way.
    There are 4 fuse boxes in the Vegas and one is on the driver side outside compartment. Which is a real pain to inspect fuses. I suggested a central location for all fuses cab and motor home which would be behind the outside TV and have that TV a swing out mounted system with the fuse box easy to see standing up and checking fuses with ease. The cable to ant switch is in a bad location up over the kitchen sink cupboard. All it has is a little green LED light that you have to push to change. But to get to it you need a step stool if you are less then 6 foot tall. Mud flaps were installed on wrong as the tail pipe side had the flap get melted by the hot tail pipe. There is a bracket that holds the mud flap between the tire and flap and each mud flap was on the out side of the bracket which made the flaps blow in the wind. Front windshield molding blew off on our way home from the dealer 10 miles down the road. That has been fixed by me and the use of glue would be suggested and having the seam at the bottom of windshield a better location not at the top roof line. Why it came off. Now that we have the motor home back I will keep posting as I see any more problem issues.
  • YOU NEED AN ELBOW FOR THE DUMP. NO TV SWIVELS, NO OUTLET IN BEDROOM AND THE SHOWER CURTAIN STICKS TO YOU, I'M TRYING NOW TO PUT TOGETHER A GADGET TO STOP THE STICKING.
    DO ME A FAVOR ASK THEM HOW TO REMOVE AND REPLACE THE ENGINES 12 VOLT BATTERY? I'M TRYING TO FIGURE THAT ONE OUT TOO.
    I SUGGEST YOU DO YOUR DUE DILIGENCE ON THIS ONE! I DON'T THINK I DID!
  • Thx for the info! I ended up not doing the deal. I'm 6-4 and just to darn big for the shower and plus we have a 3 year old who has to shower with one of us so the shower just wouldn't work.
    I did look at the 15 tho. I couldn't figure out how to release the tv. Theres no way to get your hand behind there to release it. The guys at the dealer couldnt figure it out either.
    The new shades go all the way down past the bottom of the window.
    The new shower controles are in the shower not in the sink.
    I think I might wait for the axis/vegas model to come out that will be 1ft longer. Hopfully has a bigger shower.
    I guess my 2014 Palazzo thats been a headache will stay for a bit longer.
  • Haven't seen a 2015 yet! Heard they were changing the faucets on the shower. That would be great! I have no trouble keeping the water in the shower, but often have to mop up behind hubby!! So guess the shower answer is it depends on how careful you are!! :)
    There are plenty of outlets everywhere in the coach. There are outlets in each back corner of the bedroom to plug in cell phones, Cpaps, etc.
    With regards to dumping: the compartment is cramped which always makes getting a secure hose connection more difficult than it should be. However, our dump valve is pointed slightly down, so no problem with it!
    We, too, are curious about getting to the back of the tv over the door. Thor's tech told us it comes out on an arm when you use the release lever, but we have yet to find it!!! If you get a demo of it tomorrow, please let us know how to release it!!!
    I also heard the 2015 Axis would have MCD shades. If it does, could you please check if they have worked out a way to cover all the way to the bottom of the windows? With the shades we have, there is a slight gap at the bottom because of the window knobs.
    We are really enjoying our Axis! Good luck tomorrow!
