I dont own one so I can not give you the Pro's but I did look at them and the one thing that worried me was the low GVWR of just over 10k lbs on the Transit chassis. With a slide and being full of gas and half a tank of water and 2 people you might be very close to the weight limit. Even if the total is below the limit the rear axle will almost certainly be over. Dont let a salesman tell you it will be fine, take one for a test drive and stop at a truck stop and get a weight. Then you have a real world starting point for adding water, cargo, and fuel if its not full.
