TwistedGray
Dec 03, 2020Explorer
TwistedGray wrote:
Let me start with the first question.
I have a question about the little seat next to the main door entry to the right if you are stepping into the cabin area. I have seen in a video where someone is able to access whatever is under the seat cushion by pulling out the back pad then pulling off the cushion itself.
However, as much as I try, that seat back isn't moving, at all. Clearly I am missing something here...is it bolted down somewhere? Is there some secret methodology required to pull it up/out. Do I have to remove the lower curtain rail?
What's the trick?
I did not think I would answer my own question, but I was told by a CA rep that in the newer 19G models (2013ish and newer?) the seat is bolted down to the floor from underneath the vehicle.
To get access to the space under the cushion, you have to remove the entire seat compartment (at least the first time - rig it up yourself to have it removable thereafter without having to pull the whole thing).
I said the guy, "Well, what's in that area that is so critical that you've limited access to it? In other words, should I not bother since there's no space left under the cushion?"
His response, "There's nothing in there. Go for it."
Huh? What?
What kind of design doofus decided to create an empty space that is otherwise not accessible? (facepalm)
