mbacfp30
Aug 27, 2015Explorer
I totally fill the same way. I actually looked at going with a used higher end super C. We all have had our issues some common and some unique...but I believe it is a good value nontheless. Before learning about all the slide issues...I was leary of the full wall slide. I also bought the extended warranty...so we will see. I use the coach quite a bit as the kids like to go camping...maybe not quite averaging once a month...but close. FWIW...the slide seems to work great after a year. I also don't put the slide in or out unless I am plugged in or have the generator on...don't want any power issues causing any slide issues if power caused it to stop mid way in or out.
38,780 PostsLatest Activity: Aug 05, 2026
