RobbieH
Sep 02, 2015Explorer
Sites wrote:
RobbieH,
If the actual gear(s) are slipping, it should be pretty obvious once its completely extended or retracted. Either each corner wont be fully snug against the exterior of the coach when fully retracted, or each corner wont be fully extended at full extension. To check full extension, I just measured the distance of each corner to the coach and make sure they are all the same. I think that each time the gear slips a tooth, it equals approximately 3/16 of slide distance. So it will be obvious if any have slipped.
I've seen that in the past, believe me! :) Before the change to the 3 Trax system, it pretty much failed every time I used it. The good thing is, it would fail while going in, so I was able to get home. Thank you for the info though, I'll have to measure when it is extended, because I've not done that. This is the first time the problem has occurred while I am able to fully extend the room.
38,780 PostsLatest Activity: Aug 05, 2026
