mbacfp30
Apr 04, 2016Explorer
I hope everyone is doing well. Now have 11,700 miles on the rig and all is good except a few issues. My leveling jack return line has swelled again and both rear hydraulic jack lines were leaking. However, since this has been an ongoing issue...THOR has stepped up and covered these again under warranty (18 months). Found a good shop so hoping jack lines will calm down.
Also, noticed my Onan Diesel generator drips a little coolant at (as far as I can see) the coolant drain cap. Doesn't leak when running or when sitting for extended periods of time...only after it has shut off...drips 5-7 drips (slow, slow leak) after first 15 hours after running. I flushed and replaced drain cap and washer early to fix the dripping, but it didn't. Park my rig under shade on concrete...so easy to pick up leaks, etc. Anyone else having this problem?
My battery and solar upgrade has been put on hold as I purchased a tow car. Mounted the tow bar on the car...planning on finishing car wiring and SMI braking system this weekend. Love the rig even with all the problems.
Tim
Tim
38,782 PostsLatest Activity: Aug 30, 2026
