port24
May 24, 2016Explorer
RE_Todd wrote:
So, back from the inaugural run on the new to me 2014 35SK. Issues are a dual passenger rear blow out. I believe it was a leaky dually extender, they're all going away. 5 miles from AZ on the east bound I40. The unit won't take DEF. Got to 311 miles from limp home an hour after the tire incident (Really bad day). The DEF fill is kinked between the under bay housing and the frame. I can see the conversation right now. Thor: It's out of warranty (New date 3/15). Ford: It's Thor's fault. If you climb under the unit and squeeze the flat spot out of the DEF hose, it'll fill. Generator auto start not working: Still have to figure this out. It'll trigger the start but won't follow through. Pushed around by the wind, thinking shocks and steering stabilizer!! 2375 miles in 11 days.
I have a 2014 33sw...had the same kink in the DEF and problems filling the fuel tanks. The DEF filler hose was too long. Easy fix with a knife and screwdriver. The fuel breather lines were also too long. They hung below the fuel filler tube lines for both front and rear tanks and filled with fuel. Filling the tanks took foever!! I shortened both breather tubes and rerouted the lines. I zip tied them on top of the filler tubes. Now I can fill DEF and diesel without problems.
Hope this helps.
38,782 PostsLatest Activity: Jan 05, 2026
