RobbieH
Oct 07, 2016Explorer
This equipment is under the bed. You can do it with the slide in, but there's more room to move around with it out.
I know that first picture shows them pointing up, which would imply that they cannot fall out. BUT, they are NOT pointing up from the factory. That was after I found them and pulled them up. They just lay on the floor and eventually WILL fall out.
There are three relays under there. I did not spend any time figuring out what the other two go to, but there are three systems that will potentially fail due to this problem, not just the water pump.
38,782 PostsLatest Activity: Aug 30, 2026
