RobbieH
Mar 07, 2017Explorer
11.5 means the inverter needs to be reset. Unplug from shore power, don't run the generator, turn off the inverter (panel by the entry door) for 30 minutes. Turn it back on and it should change to something other than 11.5.
Also, check the breaker under the bed, I have a picture on page 54.
Another thing, the water level needs to be checked and filled on a monthly basis if you stay plugged in. Only use distilled water.
http://www.wikihow.com/Check-Car-Battery-Water-Levels
38,782 PostsLatest Activity: Aug 30, 2026
