seal13il
Mar 07, 2017Explorer
RobbieH wrote:
11.5 means the inverter needs to be reset. Unplug from shore power, don't run the generator, turn off the inverter (panel by the entry door) for 30 minutes. Turn it back on and it should change to something other than 11.5.
Also, check the breaker under the bed, I have a picture on page 54.
Another thing, the water level needs to be checked and filled on a monthly basis if you stay plugged in. Only use distilled water.
http://www.wikihow.com/Check-Car-Battery-Water-Levels
Thanks Robbie:) Ill go check it.....I just need to know if I should go back to the RV shop and have them deal with it as all was fine with 1 month old batteries before they took it...my guess is it set there for 2.5 months without a charge:(
38,782 PostsLatest Activity: Aug 30, 2026
