RobbieH
Jun 26, 2017Explorer
You should not have to run the pump when connected to shore water. There is nothing for you to do to switch from tank to shore, there is an automatic sensor in the pump which detects when there is no pressure and automatically kicks on the pump, so whether the pump is on or not should make no difference.
As far as filling goes, I never had that problem. Maybe turn down the pressure?
