craig7h
Mar 11, 2022Nomad II
I have had and was pleased with Good Sam Extended Service. I have heard that FMCA has a good plan. I would not go with dealers plan as they tie you up in to many things. With GS I can say you will beable to get the work done anywhere that excepts the plan. Thats important if you are traveling away from home alot. All you have to do is call them up and they will give you a quote, you can decide from there.
It seems you really like this coach which is good. It seems the dealer is not very knowledgeable on its condition. Thats understandable, I would (if possible) get an independent company to do an RV inspection before you sign on the dotted line. This will give you some reassurance of the condition of the coach. It will also give you a punch list of things the dealer could fix when doing the PDI.
Good Luck and safe travels
