jolooote wrote:
It works well on AIR Antenna. The switching is done simply by turning the antenna switch box off and selecting cable/search from the menu. It finds NO Digital nor analog channels.?.?
Have you tried connecting the cable directly to the TV from the park connection? Perhaps your cable wiring has a fault in it. You might also try connecting and disconnecting the park connection a few time. I've run into more than one site with a bit of corrosion on the connection. Using the cable fitting with the longest center conductor for the park connection can also help sometimes.
