joloooteExplorerJan 23, 2019Thor Vegas/Axis engine Batt.removal thru hood.Yes, it can be removed thru the front hood opening if you don't want to 'SAW' thru the inside dash top. The battery height must be less than 7.3/4 inches high. Unplug MoHo from 115 Volt Ac. Put switch...Show More
4x4vanExplorer IIIFeb 06, 2019Thor actually designed, built, and sells an RV that requires that much work to replace a battery? :S
Related ContentClass A Axis/VegasThor Axis/VegasThor Vegas vs Axis RUVThor AXIS or VEGAS ruvPotential engine overheating
