j-d wrote:
All seven wheels should be the same and mount in any/every wheel position.
We just crawled through this with another member, it seemed the decision was going to be to stay with 16.5 tires.
Read ***Link Removed*** and be sure you understand OFFSET. Offset produces the required spacing between dual rear tire sidewalls but it isn't measured that way.
How do you plan to use this coach? Like how far do you want to drive? Stay away from your base how much/how long?
The Firestone Transforce is a good tire and the price is reasonable.
Thank you all for the reply..
Hmm...the Offset is definitely going to be a factor.
Thanks JD -
To address your ?s - I plan on driving across the country (From Oregon to New York and down to Florida and west to California and back up to Oregon.\ That's the plan.
I am on the fence about putting Firestone 16.5 Transforce tires (not readily availabe). I could just stock up while it's still available?
Such a hard decision esp. w/ limited budget.
