RVER's avatar
RVER
Thoughts on a Chevy 8.1L Gas Engine vintage 2003
So I have pulled the trigger on a Newmar Mountain Aire 2003 with the Chevy 8.1L Gas Engine. IT runs very smoothly at idle and driving seems to pull nicely through the corners. Just wondering from anyone who has owned one, caveats. I know the ones in the early 90s of the Chevy manufacturer had manifold problems but am told not so with the newer Chevy engines. I know now that GM does not put engines in RVs so is there a reason that they pulled out and am i buying a pig in a poke? Mountain Aire is a great product for sure but engine?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Mine is a 2005. Only problem is about 2 years ago it went through 6 quarts of oil faster than I could pour it in, blown engine so I'm awaiting a replacement, Hoping to do that in about 2-3 months.
    I like the engine it performs well when paired with an Allison, Has only failed me twice. once when it blew and once on a road I had no business being on to begin with.. (Had to drop my 4,000 pound towed, then drive the MH over the hill then walk back pick up the towed and drive it over under its own power).
    Only time I ever failed to make it over the hill.
  • The engine was rated to last 200,000 miles. Depending on the front end design of the coach, some had heat problems that caused the burning of the rear spark plug wires. There was a cooling kit that is no longer available but you can buy Taylor Extreme plug wires and with the proper metal heat shields around the plugs, this is a non-issue. Also, depending on the front end design of the coach, it was possible to ingest water into the air intake. Cutting and turning the tuba air intake 180 degrees takes care of this problem.
    Other than these issues, just normal maintenance and the engine will serve you well and provide plenty of power.
