thestoloffs
Apr 11, 2015Explorer
Wijames wrote:enblethen wrote:
We have an Atwood water heater, This type of add on heating element is not recommended. Sure it is out of warranty and may not hurt it. I would be careful about installing one and then again during winterizing be sure it is removed to drain unit.
Camco water Hybrid Heat
Do you know why it's not recommended for the Atwood? Luckily here in FL we dont have to Winterize.
I suspect it's because Atwood WH's use an aluminum tank, where Suburban WH's use a steel tank. The metal used in the Camco heating element may cause electrolysis with the aluminum tank.
38,776 PostsLatest Activity: May 15, 2026
