pnichols wrote:
bobbyg123 wrote:
Since I'm in the market for a used Class C, out of necessity, I'm open to a variety of different manufacturers. Without wanting this to turn into a brand loyalty debate, what can you guys tell me about the different Class C makers?
I'm in the market for a 25-31' camper, and the makes I'm consistently running into here in the Pacific NW are Thor, Sunseeker, Minnie Winnie, Tioga, and Jayco.
Any input on these would be helpful.
If you are considering a small one close to the 25 foot length end of your criteria, make sure it's on the E450 chassis (Ford) or 4500 chassis (Chevy). The respective E350 and 3500 chassis are not heavy duty enough for a 25 footer.
I agree in that 25 feet is a good cut-off between a Ford E350 and an E450 chassis, a Chevy 3500 and a 4500.
An E350 chassis at 24-11" would be fine as long as the frame was stretched increasing the 158" wheel base to notably more. This would better distribute the weight between front and rear axles, properly utilizing the extra load capability of the front axle.
Most short rigs have too much weight on the rear axle, and too little weight on the front axle causing "rear end sag". The condition also negatively affects handling. Our 11 year old E350 rig is 23'-8" long with a Ford standard 158" wheel base suffers from it. I had to invest in suspension upgrades to get the handling just right. Our rear end sag is very slight, a non-issue.
pnichols......
I am not sure the balance of your list exists in a single motor home. I am trying to be funny, but it's not working well :) It's good to keep such things in-mind if you narrowed your selection to a final two or three. Though I beg to differ on a few of your line items.
