dougrainer
Jan 21, 2016Nomad
As of Monday the 18th. LCI cannot tell what parts are being made or when they will be available. They just stated within a few months. They (tech service) does not even know what the recall kit will involve. Tiffin has been replacing LCI that Break at the Pivot bolt with Kwikee as LCI steps are no longer available. Certain parts are available but not the complete step. IF you have the Pivot bolt shear OFF, LCI has NEVER had a replacement for that as the nut the Pivot bolt screws too is welded. IF that Pivot bolt ever broke under warranty, LCI replaced the complete step. I believe the recall will just be a band aid that will prevent loss of control if the Pivot bolt breaks and prevents injury to the RV'er when he is on the step when that Pivot bolt breaks. Since the Pivot bolt is welded to the mount nut and the Mount nut welded to the top of the step frame, there is no easy way to modify the Pivot bolt assbly. Doug
38,766 PostsLatest Activity: Jan 10, 2026
