denbie, before you install a trac bar you may want to check a few other things. 1. Tire pressure. If you are running on too much pressure your MH will handle poorly. Wiegh your MH and insure you are balanced with your stuff and then set your tire PSI according to Mfg specs. I run 90psi front and 85psi rear. Yours may be different. 2. Also the amount of water in your fresh water tank can effect the handling. I carry atleast 1/2 tank for the weight. 3. your shocks may be worn out if they are 2002 model year. I installed Koni shocks and it made a huge difference in all around handling and ride.
