dougrainer
May 24, 2020Nomad
You see more complaints about Dometic because they are the largest supplier. Since they make MORE, they will have more statistical failures. Your tstat and Communication cables and roof top controls are specific to Dometic. If you go to another Brand, you will have to run new Tstat Cables from the wall to the roof and change out the wall tstat and the upper control boards, which adds cost. Since your RV is almost 12 years old, I would purchase 2 Dometic Penguin AC only units and a new 10 Button wall CCC programmable wall Tstat(about $95). This is all plug and play. The wall tstat will control both roof AC's and is programmable. The Dometic Penguins come with the new 10 button control boards already installed. Doug
