OFDPOS
Apr 22, 2018Explorer
Ron & Pnichlos
I'd highly recommend the Bilstein's HD on the front.
Ron and Pnichols ... Have you weighed the MH ready for travel ?
We don't have a toad...
Ours is 29.7 feet long with a 200 inch WB.
While up in Or. we pulled into a closed weigh station. Did the front 4160 lbs and rear 9300 lbs.
With both of us sitting up front , Fuel tank 3/4 plus full. FW tank 3/4 full, propane tank full, a few gal in the BT , GT empty. Fridge stocked and along with clothes etc.
Then pulled just the right front on... 2200 lbs then right rear 4850 lbs. centered on the scale pad best I could.
As I was turning around to weigh the Left side a logging truck came in so we waited for him to leave. He sat there for quite awhile. So we drove off I didn't get a chance to weigh the other two corners !
But by those #'s I got , the right side is heavier that the left !
But again without getting to weigh ALL 4 corners not really sure how the #s would add up.
With just the right side corners weighed it would appear there's a difference of 250 lbs right front vs left front and 700 lbs right rear vs left rear. I have my wife beat by at least 60 lbs plus had 5 1 gallon jugs of water sitting just behind pass seat.
Both slides are on the Left side...
I need to get all 4 corners weighed to verify true weight between the R&L...
38,780 PostsLatest Activity: Aug 05, 2026
