Daveinet wrote:
427435 wrote:
jhilley wrote:
I run about 6,000 miles between oil changes and have the oil tested at
Blackstone Labs
The tests confirm that I could go a little farther between oil changes, so 7,500 miles should be ok. This is with quite a bit of mountain and hot weather driving pulling a Jeep Cherokee.
It is good to get an oil analysis just to see how your engine is wearing.
X2
Having your oil tested is the smartest way of doing it.
I'm not sure I understand the usefulness of this test as it relates to change interval. I see no place where it tells you how much additives are still in your oil. while it gives an indication of wear, it is telling you after the fact. for example, how do you know if the oil still has enough zddp in it? if you are starting to see increased wear, you are finding out after the fact - after the increase has occurred is too late.
Same as medical screening tests. It will also give you recommendations for rectifying the problems detected, such as checking the air filter and intake if too much silicon is detected.
This is comment from one of my tests
"JOHN: Universal averages show expected wear levels for the Ford 6.8L V-10 after ~4,500 miles. You ran longer and
that's part of the reason iron is higher than average because iron will accumulate in the oil during a longer oil run. But
we also suspect silicon may be a little dirt in your engine and that could have caused the extra aluminum and some of
the iron, perhaps. Change your air filter to see if that takes care of it. Otherwise, this sample is in fine shape. The low
viscosity and trace of fuel are harmless. The TBN of 2.3 is good since 1.0 is low. Try 7K miles next."
It doesn't show the additives left, but it shows what is controlled by additives and whether or not they were with in normal ranges. As far as wear, how would you predict in advance? This tells you before your engine is ruined.
