mhbell wrote:
Executive wrote:
IMO, Buying tires based on price alone is a fools game. Doesn't matter how far you travel. Doing so on cheap tires can have disastrous, even fatal, results......Dennis
I agree with you 100 percent, However Dayton tires are the second tier of Bridgestone tire company. I see no reason to pay $400 a tire when a $200 tire will do just as good on a GVWR 18000 Lb Rig. Especially when it is driven so little and mostly short trips. If it was a GVWR 26000 Lb rig or heavier I could see spending more for a Michlin or Goodyear tire for RV's. JMHO.
Mel
Goodyear and Michelin if your not aware make the only true RV tire. There made out of very soft rubber especially for RV applications due to all the time sitting in one place that RV's endure. All other tires are hard rubber truck tires. Just wanted you to be aware of this! Good Luck in what ever tire you purchase.
