Mr.Mark wrote:
Our coach came with Centramatic wheel balancers. These attached to the hub. This is what it says from the Centramatic website:
"Centramatic's patented "On-Board" balancing technology is time tested and proven to increase tire life, reduce maintenance cost and increase fuel economy by constantly balancing the complete wheel assembly."
MM.
Centramatics do work well, but they are not an inexpensive solution. The theory the Centramatics use is exactly the same as for beads--inside the Centramatic rings are little balls and some sort of a damping fluid, I believe.
In short, with beads, I don't think there would be any advantage to the original poster to using Centramatics. Neither one is too effective against tires that are not round (nor, for that matter, is traditional balancing).
