ECones's avatar
ECones
Tire checking frustration
I'm new to this so be kind. But I get so frustrated trying to check my inside rear tires. The valve for the inside tire is on a goofy little bracket that clamps, not very securely, to the wheel with one small screw. It won't stay in place. Every time I check the tires, one or both of them has worked loose, and I have to remove the hub cap and cinch it down again before I can check the pressure. There must be a better way. I would spend money to fix this. Suggestions would be greatly appreciated.
