GHOST1750ExplorerMay 26, 2017Tire coatingHow many of you use something to blacken your motor home tires, if you do what do you use. I understand some of the blackening causes the tires to dry out and crack.
harold1946ExplorerMay 27, 2017X3; 303 is the best protectant I have found. Makes the tires look nice and is rated at SPF 40 to help protect from UV. Been using it since 1993.
Related ContentBias ply vs. radial tiresBest Roof CoatingAre you familiar with Duck Coat Roof Coating??Class A tire protection coatingsRoof coatings.
