Sagecoachdriver wrote:
My 2004 Winnebago Ford E350 has Michelin tires that were put on last January because of the recall. 2 months ago, I had it aligned for our fall trip to Arizona. Tires had no wear. We traveled about 1400 miles and most of it was fighting high gusty winds. Usually had the wheel at 11 o'clock or 1 o'clock for hours at a time. When calm, the MH tracked perfect. When we got home Saturday, I noticed that the tires had feathering not just on the outer edge, but across the entire tire.
Checking the web, I found that feather is usually due to toe in. Could the feathering be caused by the wind? I have the computerized alignment numbers before and after going back 6 alignments and the toe in is well within the perimeters set by the manufacturer and the after alignment numbers.
The front tires will probably have to be rotated either swapping sides or swapping sides with inner duals because of stems. Alignment shop only guarantees alignment for 30 days and it's 65 days. So I would probably have to pay for another alignment, or perhaps they may give me a break on price.
I think it's the wind! What do you think?
Oh, the tires were properly inflated for my weight and I checked them daily while on our trip.
Yes, a constant crosswind can cause feathering on your tires. It would be like trying to steer constantly in one direction and that causes the tires to develop a slip angle, which in turn causes the tires to develop feather wear.
