wa8yxm wrote:
The folks who stuck the sticker have to make a few assumptions... Like how much weight you are going to carry.
So, if you happen to load your rig in EXACTLY the manner they assumed, their pressure rating is proper..... What are the odds of you doing that (Approach zero)
You are, however, only 5PSI over the upper recommended... Many folks suggest running 4 PSI over tire maker's recommendations... I will not argue with them at all... So run 85-90 would be my suggestion.
Thanks. I reduced from about 91 to about 86 on front and went for a short ride and it made a nice improvement. I have Kelderman air ride on front so the ride is already pretty good. I am striving for perfect. I will trade a couple of years of wear for good ride. Couldn't do Kelderman on rear because of hot water heater location. I am putting Koni FSD's on next week. I am confused about the rear duals. According to weight divided by 2 I can run 85 easily on duals but always thought rears took a bit more psi than front. No info on that just something that seemed to stick in my brain.
