haste maker wrote:
I have a 32 foot Class A that has a gross weight of 18,000 lbs I need to replace the tires due to age, it has 14 ply tires on it now...I am thinking about going to a 16 ply tire with the new tires.
Has anyone done this, & if so what were your reason for doing this, also did it change the ride to a harder ride?
Can of worms, . . . . soon to open.
IMO, stick with the same payload rating.  Every major tire manufacturer has their own proprietary blend of rubber compounds (tread and sidewall compounds can be different), tread patterns, and carcass construction which THEY feel is best for your application.  That may differ from your opinion.
https://www.readingtruck.com/understanding-truck-tires-load-ratings-and-sizes/
Unless you have specific reasons for changing tire manufacturers, IMO you should stick with the same one.  Remember, you are spending a lot of money, and, if you son't like your new tires, you are stuck with them for a while.  Tire manufacturers also change tire compounds, construction, load ratings often so even if your new tires are the same as the ones they replaced, they may not actually be "the same."
Chum lee
