this subject was probably beaten to death but I'm stumped. I can't find any info inside the motor home for recommended tire pressure. The sidewall on the tires say 120psi. The dealer has 85 lbs in ...
Best thing is have your coach weighed to find out the weight on the front and rear axles, then using the tire manufacturers load inflation chart inflate your tires accordingly.
Our coach with a tag axle weighs 21,230lbs loaded for travel. Using the tire manufacturers load inflation chart, 80 psi in all tires will safely support the weight of our coach.
