this subject was probably beaten to death but I'm stumped. I can't find any info inside the motor home for recommended tire pressure. The sidewall on the tires say 120psi. The dealer has 85 lbs in ...
I believe the big problem is that Sampson does not provide the chart he requires. I have the same issue. Both Goodyear and Michelin charts have 80-85psi minimum. My Coachman mirada 34mbs weighs 6000 front and 10,100 rear on scale which is below the minimum so I run 85psi.
