btilfan
May 04, 2014Explorer
tire pressure ?
this subject was probably beaten to death but I'm stumped. I can't find any info inside the motor home for recommended tire pressure. The sidewall on the tires say 120psi. The dealer has 85 lbs in ...
Effy wrote:btilfan wrote:
So my front axle is 5,880 lbs and the rear is 10,520 lbs.
Can't find a chart for the sampsons. Do you think it would be the same for Goodyear?
If so what do you think my tire pressure should be set at?
(goodyear chart will not come up on my computer)
245/70R 19.5
Can you call them?
