btilfan
May 04, 2014Explorer
tire pressure ?
this subject was probably beaten to death but I'm stumped. I can't find any info inside the motor home for recommended tire pressure. The sidewall on the tires say 120psi. The dealer has 85 lbs in ...
rk911 wrote:Effy wrote:btilfan wrote:
So my front axle is 5,880 lbs and the rear is 10,520 lbs.
Can't find a chart for the sampsons. Do you think it would be the same for Goodyear?
If so what do you think my tire pressure should be set at?
(goodyear chart will not come up on my computer)
245/70R 19.5
Can you call them?
yes...call the mfg or dealer but be sure to ask where to get a copy of the inflation chart and not what pressure to use. odds are the dealer won't know or will just tell you to inflate to whatever is on the sidewall. but remember you need to get your MH weighed.
if your tires were goodyear and mfg before 2/28/06 the minimum inflation would be 70-psi; for tires mfg after 2/28/06 the minimum inflation would be 80-psi. your dealer told you to use 85-psi. i'd leave them there, at 85-psi, until you get your MH weighed and have the inflation table in your hands.
