CapriRacer
Sep 27, 2020Explorer II
William B wrote:CapriRacer wrote:SGTJOE wrote:
I can't seem to find a psi chart for Continental tires. Anyone on here that can steer me to one.
Sorry, but Tire Load Tables are NOT specific to a brand of tires. They are published by tire standardizing organizations such The Tire and Rim Association (US based) and are the same regardless of the manufacturer. You can sometimes find portions of those tables published by tire manufacturers, but those are only reproductions of what the standardizing body published.
So to answer your question: ANY table will work. Just make sure the table you use is appropriate to the application. There will be difference based on what kind of vehicle and the intended service.
Then why do two different Michelin tires of the same size 295/80R22.5, the ZXA2 and the H Coach have different load tables, and why do my Toyo's of the same size have yet again different tables? Maybe that works for car tires, but it doesn't work for large truck/RV tires
Because Michelin - in their infinite wisdom - didn't tell you that they modified the tables according to the service (in particular speed). Figures that Michelin would complicate something that is supposed to be simple! (Jadatis has a post above this one that explains in more detail.)
As far as Toyo is concerned - I couldn't find a load table on the internet for any of their 295/80R22.5's. Do you have a link?
38,780 PostsLatest Activity: Aug 05, 2026
