Sandia_Man
Jul 18, 2016Explorer II
It would be abnormal if they didn't rise in psi once warmed up. An 18psi increase is a bit on the high-side but I've seen our psi increase nearly that much on a couple of occasions. As long as they return to cold psi setting more than likely all is well. Many worry excessively about the psi increase but engineers have factored in this normal occurrence when designing the tire. It's the main reason why psi should only be adjusted when tires are cold.
