pusherwanabe's avatar
pusherwanabe
tire pressure gauges
What do you all use to check your tire pressure? With 110 psi required in my coaches tires most air gauges don't go that high.
Thanks
  • I also use a Milton, easy to use and accurate. I also picked up a good inflator for adjusting air pressure. The cheap inflators don't have enough "grip" to hold on the valve stems.
  • Thanks every one for your suggestions. No I haven't weighed the coach yet, just going by Tiffin and tire recommendations.
