dbates
Apr 15, 2015Explorer
You can't tell for sure until you establish the RV weight on each of your individual tires. Last year I went from Michelin 225/70R19.5 to Hankook 225/70R19.5 tires and was advise that I should use the same tire pressure I used for the previous 9 years with the Michelin tires which is 70PSI.
You really need to establish the weight on each tire and set you PSI accordingly. Click HERE for Michelin's tire guide. It will explain how to weigh your MH in order to establish the proper PSI for your tires.
Dave
Dave
38,782 PostsLatest Activity: Sep 01, 2026
